M2P shutter speed
charliesRig
My new bird with just 10 flight is abnormally slow
When trying to take a picture or activate the video mode .
As compared to my MP1
Which is instant
Is it me or is there lag on M2P camera activation.?
....cR
Thanks for you Imput CD
******** Problem Solved *******
Although my MP1 Flies well on a Class "1" ultra
M2P does Not
78717
My M2P Flies well with ...This
78718
........I welcome your Feedback .Thanks
..........cR
I think u’ll find that the so called lag is actually the camera trying to focus. Since the Mavic has such wide angle lens u can focus on anything in the middle distance the switch toManual focus. Now you’ll find it’s pretty snappy.
The M2P can capture over 100 MB/s so u need a Class3 micro sd
Reactions: charliesRig
I’ll give it I try thanks for the tip
...... cR
I also experienced a slowness between shots with my M2P while using the same SD Cards that worked fine on all my prior DJI Drones until I bought and used the SanDisk Extreme PRO microSDXC UHIS-1 Card. This is the same SD Card shown in the DJI Store to work with the M2P. This card will write up to 90MB/s. This card is selling on Amazon for $20 for the 64GB SD Card.
V30. The V number is what matters. Above V30 and you will never have an issue.
BobShaw
