From what I have read the time limit relates to that app/phone connecting to the internet and has nothing to do with the interval between flights.
I am not sure if
a) the phone simply needs to connect to the internet within the allow time period or
b) the app needs to be running whilst the phone is connected to the internet.
In addition if you have multiple devices running the fly app and one of them logs out of the app and then connects to the internet then each of the other devices will also be logged out when they next connect to the internet.
Finally I suggest you read the dji post in
If that link doesn't work the post is
".1 In DJI Fly 1.12.4 and later versions, an account remains in the login state for 90 days after the login even if the app is disconnected from the network, and a reminder will be pushed before the login expires.
Note: Within 7 days of expiration, the APP will remind once a day if the conditions are met; Condition: During the 90-day period, the APP is not connected to the Internet
Note:Your login will expire in %@ days. Login again required after expiration. Flight altitude and distance limits may apply if not logged in. Connect to network and update account info in time to keep using app.
2. If the device is connected to an abnormal network, such as an open Wi-Fi, it needs to redirect to the login page, an expiration of the login will be triggered, and it is required to reconnect to a normal network to log in again.
3. When one device logs out of the account, the other devices logged in with the same account will automatically log out by default if multiple devices are logged in simultaneously. This is a common scenario; for instance, if a user's phone and a remote controller with a built-in screen are both logged in, and the phone logs out, the remote controller will automatically log out when it is connected to the internet."
NOTE TWO THINGS in the above
1} 90 days vs 1 month, I am not sure which is correct. I think I have seen a different version of that post on the DJI forum but can't find it.
2) section 2, what is an abnormal network ? If it is a public WiFi network such as those in shops ............
