CanadaDrone
- Joined
- May 9, 2018
- Messages
- 2,176
- Reactions
- 2,066
The advantages of shooting higher resolution go well beyond what display you plan to play it back on. Just to name a few on the video side:There is no doubt that the M3 has some real "improvements" over the M2 under some circumstances. The thing with the AOAS is that while an improvement isn't fool-proof. I think it might be great in a "follow me" situation much like the skydio. We know that there is potential for it to shoot higher resolution images than the M2's or Air2s. The question there is will current monitors be able to see and take advantage of the extra resolution?
1) More leeway for 'lossless' cropping/panning/zooming if your end goal is an output resolution lower than the capture resolution. You can worry about composition after the fact and have a buffer for making mistakes.
2) The ability to grab higher resolution stills from any frame within your footage which is more than enough for a nice print (a 5.1K frame is ~14MP).
3) Higher resolutions downsampled to lower resolutions will result in higher image quality (one reason why oversampling is used)
4) Higher resolution gives better color fidelity and better gradients
This is why 8K video is such a big deal despite 8K displays being quite uncommon, but all the same principles apply proportionately to lower resolutions as well.
In terms of still images, the drones in question are all the same resolution, so the advantages there primarily come from the physically larger sensor.
