Matrice 30T Flight with a Lost Link
It was a Matrice 30T that had a Lost Link
What is a lost link?
One possibility is that the remote controller powered off mid-flight.
Lost link: "A UAS lost link is the interruption of the command and control (C2) signal between a drone and its ground station, which can be due to a lost uplink (commands from ground to drone) or downlink (data/video from drone to ground). When this happens, the drone automatically executes pre-programmed "lost link" procedures, such as returning to a home point, to recover safely. "
I thought the same, but the RPIC stated the controller was on the whole time. I also thought that maybe the app, DJI Pilot 2 froze, but that does not seem to be the case.
The drone was not far from the pilot at all and there is nothing in the area where the lost link happened that produces interference.
I'm hoping the pros can see something I don't.
Sorry for the confusion. I just wanted to understand what you meant by "Lost Link". Maybe the RPIC used that term.
It's also not clear whether you're describing something you saw elsewhere or if you were speaking directly with the RPIC about the incident.
And the RPIC could see the live camera feed the entire time?
Unfortunately, there's nothing to see.
When the flight log ends, everything looks normal, and both the uplink and downlink signals were at full strength. If the RPIC didn't manually initiate RTH, it likely means the uplink suddenly disconnected.
Thank you.
A quick summary:
I was told the drone without warning went into Return to Home.
They could see the video feed, they could not control the drone with stick inputs.
The drone landed at the home point.
I am at a loss. The flight log reminds me of one from an Anafi that lost all power and fell to its death since it just cuts out.
It supposedly has the newest firmware. I still have to go and check the drone myself and will ask some more questions.
Gryphaen
