Mavic 2 Pro Lossing Video Transmission
Genzeka
I’m flying my Mavic 2 Pro for the second time. I keep losing video signal. Is this a connection issue or a Software issue?
Make sure the cord to the phone is plugged in nice and straight in the phone.
Power your phone completely off, and restart it. Make sure all other apps are closed, Make sure you have plenty of memory, (phone memory) if the phone relies on an SD card for memory, make sure DJI go4 can use it.
Put the phone in airplane mode (no wifi, no cell) and see if its better.
THEN try the signal trouble shooting if it is still a problem.
Reactions: Genzeka
If it does it again, if a different spot, probably not interference.
Most common issue is connection to the phone. But lets see where the others are leading you.
iqbalNananannama
