Mavic 2 zoom vision sensors calibration freezing.
borabozkurt0606
Greendale, Wisconsin, USA
Hi there. Im having a problem with calibrating my all sensors. I cant finish calibration steps. Its lagging and vision sensor images on the screen are turns into black and freezing. I contact to DJI support they said you need to send it to us but it will take 60-90 days at least. I don't want to wait 3 months. Front, bottom and upward sensors are working but i cant even calibrate them. i tried 2 monitors and pcs and i post a video about my problem on youtube. Here it is=
So my question is:
- Which part should i replace? What's wrong with my device? (IMU?), (software?), (cable, flex?)
Reactions: Cafguy
You will need to do some Config file editing to even Maybe get that to work. The error code your Drone is showing indicates you need an IMU. That will clear all of your errors.
You have to give it the screen size in the Config file. However I have no idea how that is done. I think replacing the Faulty IMU will clear the Vision sensor Error.
Yes. The Error code that is showing says the IMU isnt working. The IMU would cause this problem.
dnlweijers
