Mavic Air 2 controller question
hidroela
usa
would like to know the maximum aperture of the mobile device holder measurement to look for alternatives tablet.
thanks in advance.
It’s not big enough for a tablet.
As has been posted here and published as part of the specifications found on DJI.com, the maximum device size without an adapter is 180×86×10 mm (Height×Width×Thickness) . The width is the main one you'll need to worry about for a tablet, and the thickness for anyone who wants to use a case.
You can use a tablet adapter if you want to go that route.
Most of the Mavic 2 tablet holders should work just fine.
Just make sure you have a long enough USB-C to Lightning cable to reach for iPads.
Hi, I purchased a tablet holder for my Air. My Samsung Galaxy tab S5e tablet uses DGI go 4. See photo. Works well. You will need a longer USB-C cable also.
Hope this helps.
SarahR1202
