Situation:
Or maybe just forget about the whole thing and just use this one for parts. What do you think?
- I'm a new drone pilot, fourth flight, foggy conditions, no wind. (I should have known better than to fly it in fog).
- 3min into flight, motor error 30163 "Check Propellers". Condensation from the fog was probably entering the system,
- 7min, I manually put it into RTH, drone turns around then stops, it's in RTH mode but doesn't return. Confused I take it to 170ft thinking maybe a tree was in the way (it climbed the last 20ft on it's own. It seemed confused too). Still not returning, it begins to lose altitude.
- at 7:43, still 110ft in the air, motor quits, drone hits the ground at 40mph, snapping an arm, breaking the gimbal, clay packed in a rear motor and probably more. I assume DJI will want $500 to fix, or maybe some super glue...
- After some cleaning and some temporary duct tape, props are spinning free and I'm ready to test the electronics. Props do their little flicker startup thing, seem fine but ESC Error, 30085. Time to download some low level diagnostic software from DJI.com, check POST, test each motor individually, etc. Boy was I in for a surprise...
