Mavic air 2. Multiple errors
jakobh
Germany
Hello,
After searching half the internet I'll try it here.
I have a DJI mavic air 2 with multiple errors (see error codes below).
I have already exchanged the GPS unit and the IMU, but the same errors always occur.
I checked all the cable connections so there are no loose cables.
I'm beginning to suspect something is wrong with the motherboard.
Can someone help me there?
flight checklist
Gimbal not recognized. repairs necessary. Please contact DJI Support.(Code: 40012)
Gyroscope initialization failed. Restart aircraft. (Code: 30045)
Barometer initialization failed. Restart aircraft. (Code: 30047)
IMU calibration required. Please calibrate. (Code: 30050)
Low GPS accuracy. Please fly carefully. (Code: 30049)Start not possible
No GPS signal. Stable hovering not possible. Please fly carefully.(Code: 30007)
Hello,
flight checklist
Please use a smaller size font.
Your posts are HUGE!
Reactions: Capt KO
When you get tired of pulling your hair out, do a repair ticket with DJI customer service. They provide labels both ways and do turn around in less than 2 weeks. I've had great luck doing this and cost much less than expected.
Good luck
Welcome to the Best forum for Mavics - A tip and an answer
1. STOP posting so large WHY? we can read print of normal size here.
2. contact DJI your drone is displaying a lot of warnings and most likely has a short or a bad tab on a board I would send it for repair .
any updates on this subject? I am having the exact same problem, replaced imu, and gps board and nothing... was flying perfect last time i used the drone, waitied a couple weeks and i have a these errors.
Hello,
flight checklist
I had the same issue and tried all the suggested fixes. I sent it in to DJI and this was the fix.
CTD
