Mavic Air 2 Precision Landing Accuracy - Tripod vs Normal vs Sport modes
Chris Mitchell
Pembroke Pines, FL
Site
www.youtube.com
Is there a difference in Precision Landing accuracy in the three different flight modes - Tripod, Normal and Sport - for the Mavic Air 2.
Lets find out!
Reactions: xunhui
Very good and interesting testing. I like fly in normal mode since is the most efficient for batteries, motor and electronics. Will be interesting do the same test at low light situations like before sunset or even nights. I know precision landing is not supported at low light but will be nice to see the result to see how off is on this mode.
All good points zeufl, thanks for the input. I may try some Precision Landing tests in low light at some point.
Your drone doesn't autoland in Sport Mode or Tripod Mode or Normal Mode.
The autolanding is part of RTH Mode which is a completely separate flight mode.
There's not much to test.
Either the lighting is sufficient and Precision Landing will work, or if lighting is not suitable, the landing will use GPS alone.
Reactions: hiflyer201
I have always been impressed with the landing accuracy of my MA2 I use a landing pad as much as I can. I winder is it would be as accurate with out one?
As long as there is a recognisable pattern/texture at the landing spot, it doesn't matter if there is a pad or not.
If the area you are launching from is plain grass or an unmarked parking lot, for example, the precision landings won't be as accurate. The pad helps crate a sharp contrast for the vision and infrared sensors to pickup.
I Know the M2's have landing lights that come on automatically on decent, and from what I see the MA2 does as well. I have flown at night when Precision landing was executed with just about zero light other than that from aircraft. PL was accomplished fine... So that doesn't say that what you said is inaccurate as "Sufficent" is still in play. But I felt it worth mentioning as it doesn't have to be ambient light, as some aircraft are equipped to give light needed to do the function.
djimini3
