Mavic air 3
Doronron
Lancashire
I bought myself an air 3 it looks fantastic but can anyone tell me what I’m doing wrong ? The drone works fine but not been able to fly it yet because the RCN 2 is not working properly the screen is blank so can’t register or anything like that can anyone help both controller and drone are fully charged and has green and red lights on but no connection with drone 😡
Try a different cable.
What do you mean "the screen is blank"? Like it's not powered on?
One trick with DJI devices is to turn them on, you press the power button, release and then press and hold until the LED's all turn on.
Maybe take a photo with your phone and post it so we can see what's going on?
Like I said, I know how to turn it on
Uh oh. If the screen is not coming on, maybe you have a defective RC2. You might have to return it. Probably worth a call to customer support first. But if all the green lights and the red light is on, the screen should be on, and it's not. So that's my guess.
If you DO return it, maybe get the newer model? The Air3S instead?
Hello from the Crossroads of America Doronron.
Hopefully you'll get it sorted out.
Welcome to the Forum. :cool:
Welcome to the forum from the beautiful woods of Maine,USA!
There’s many knowledgeable members who are willing to help you with any questions you might have. Search the forum using keywords and if you don’t find an answer, post your questions and I sure you’ll get a quick response!
Fly safe and stay safe!
I had the same issue and found out that the cable is polarized and I had it backwards. I assumed that USB cables are bi-directional but it isnt in this case. The cable end on one side will either have a label on the top side or a usb symbol on the metal thats the side that has to go into the controller. - At least for me.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
I am sorry that I cannot help you with the issues you are having now, but perhaps this advice will prevent other issues fron occurring…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air 3.
After you read all the material, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Phly858
