I dont think you can mount props incorrectly on the AIR.Are you sure that you have the props on correctly? That flight pattern normally happens when they're on the wrong motors. You should have the white marks on the props mounted on the correct motors.
There's been quite a few examples in the last 18 months reported in here that were caused by incorrectly (white marks not matched) fitted props. If it can be done, it will be done!For the heck of it, I tried again and it does not mount without crunching those little ears into the motors
