Just got my Air and unlike my Mavic Pro the controller for the Air does not hold my mini snugly. It will slip right out of the Air controller. The Pro holds it very tight. Anyone notice this?
Yeah its not as tight as my Pro or SparkJust got my Air and unlike my Mavic Pro the controller for the Air does not hold my mini snugly. It will slip right out of the Air controller. The Pro holds it very tight. Anyone notice this?
So in theory fitting a cheap silicone case to the mini should give a better fit.Have the pro as well , they made the mavic air controller wider to fit phones with the case on. So I assume that you will have this problem with Ipad mini
Getting close to buying an Air. I am still confused as to whether the controller will fit an IPad mini? IE, will it stay in there securely?
The only thing you need the gps for is if you use Dynamic Home Point. DHP is handy if you're flying from a moving platform like a boat. Otherwise, you do not need it.I was thinking about buying an ipad mini 4. Do I need one with the cellular for the gps?
Thanks for that knowledge.The only thing you need the gps for is if you use Dynamic Home Point. DHP is handy if you're flying from a moving platform like a boat. Otherwise, you do not need it.
You still don't need GPS on the tablet, the drone's location will be on the map from the GPS in the drone. You will need to have the map up, either by having an internet connection (you could tether to your phone) or having cached it when you were somewhere that you did have internet.Thanks for that knowledge.
Next question about GPS. I read that if I do not have gps on my tablet and my drone crashes. Can I pull up the app on my phone and look for it using the gps on my phone?
Thank you.You still don't need GPS on the tablet, the drone's location will be on the map from the GPS in the drone. You will need to have the map up, either by having an internet connection (you could tether to your phone) or having cached it when you were somewhere that you did have internet.
If you switched to the app on your phone, you wouldn't be able to use the Find My Drone feature because the app would not have been connected to the drone so it wouldn't be on the map.
