Mavic Air arm snapped
I got everything put back together and it flies perfect except for the right vision sensor doesn’t work. I tried to solder it but it didn’t seem to work. Any tips?
I am not exactly sure what it does but it has 4 leads that need to be connected to each solder pad. It is possible that one of them was torn off.
If you can find a scrap MA core board, one of those components can be recovered via on-air rework.. Then you should solder it back on and the vision calibration should work fine again..
I have the small black box still. I do see one of the metal pieces might be broken. I will try and see if I can find another one. I also need to get a micro soldering kit
Hey OP, glad you were able to fix it yourself. For anyone else wanting to do some surgery, I suggest taking a series of pictures or video of each step before taking apart. It is really handy to refer to when you can't remember which wire goes where.
Reactions: Curtismqt
Definitely do this! Great tip!
It is tiny! It was easiest for me to to the re-soldered work with the motherboard out. I happen to have a decent Hakko soldering station with a reasonably fine tip. A magnifying lens or microscope is almost a must.
Best of luck.
DaveLJ
