Wow. I figured it had to be something catastrophic since I had no control whatsoever and it wasn’t returning home. I really hope DJI will replace this. Sucks that I lost a nice ND filter and SD card as well.
I forgot to include the event stream in the post above. You can see the FC failing to resolve the problem even by switching IMUs:
310.528 : 18721 [L-FDI][FDI] ns atti(0) tilt is outlier
310.528 : 18721 [L-FDI][FDI] ns atti(1) tilt is outlier
310.531 : 18722 [L-FDI]NS(0) FUSION(0): fault on , disagree
310.531 : 18722 [L-FDI]NS(0) FUSION(1): fault on , disagree
310.531 : 18722 [L-FDI]fatal error: no ns with level < 4 !!!
311.229 : 18757 [L-FMU/LED]action changed. imu error:ns_abnormal(3)
311.395 : 18765 [L-API]get_id_index_by_basic_cmd: cmd 14 index 9
311.395 : 18765 [L-CMD]exec_fc_basic_function index 9
311.395 : 18765 [L-API]exit_landing_check
311.395 : 18765 [L-CMD]basic_cmd_table send_id 2
311.395 : 18765 [L-API]basic_cmd_exit_landing
311.395 : 18765 [L-N_MIS]req abort all for app_exit_landing
311.413 : 18766 [L-N_MIS]Switch new mis 3 req 2 from mis 26 req 16
311.413 : 18766 [L-FLYMODE]SWITCH2HOVER!
311.428 : 18767 [L-FDI]NS(0) FUSION(0): fault off, disagree
311.428 : 18767 [L-FDI]NS(0) FUSION(1): fault off, disagree
311.429 : 18767 [L-FMU/LED]action changed. Normal Flash(0)
311.429 : 18767 [L-FMU/LED]type:0, normal flash action:
311.429 : 18767 [L-FMU/LED]c0:0,15;c1:0,3;c2:0,13;c3:2,3;c4:0,10;c5:0,3;c6:0,10;c7:0,3
311.600 : 18775 [L-FDI][FDI] ns atti(0) tilt is outlier
311.600 : 18775 [L-FDI][FDI] ns atti(1) tilt is outlier
311.608 : 18776 [L-FDI]NS(0) FUSION(0): fault on , disagree
311.608 : 18776 [L-FDI]NS(0) FUSION(1): fault on , disagree
311.608 : 18776 [L-FDI]fatal error: no ns with level < 4 !!!
311.628 : 18777 [L-FDI]NS(0) FUSION(0): fault off, disagree
311.628 : 18777 [L-FDI]NS(0) FUSION(1): fault off, disagree
311.715 : 18781 [L-FDI][FDI] ns atti(0) tilt is outlier
311.715 : 18781 [L-FDI][FDI] ns atti(1) tilt is outlier
311.728 : 18782 [L-FDI]NS(0) FUSION(0): fault on , disagree
311.728 : 18782 [L-FDI]NS(0) FUSION(1): fault on , disagree
311.728 : 18782 [L-FDI]fatal error: no ns with level < 4 !!!
312.446 : 18818 [L-FDI]NS(0) FUSION(1): fault on , disagree_with_mini_filter
312.466 : 18819 [L-FDI]NS(1),fdi req switch to mini filter
312.470 : 18819 [L-N_MIS]Fail to check mis 3. Reset
312.470 : 18819 [L-N_MIS]Exit mis 3. New mis 2
312.470 : 18819 [L-N_MIS]Switch new mis 2 req 1 from mis 3 req 2
312.470 : 18819 [L-FLYMODE]GPS2ATTI!Init atti dynscale scale 15.615585
312.486 : 18820 [L-IMU]userId[3] idx[1] mini_filter_used state:1
312.805 : 18836 [L-FDI]NS(0) FUSION(0): fault off, disagree
312.805 : 18836 [L-FDI]NS(0) FUSION(1): fault off, disagree
312.805 : 18836 [L-FDI]ns req:fdi,1to0,reason:disagree_with_mini_filter,result:succeed
312.805 : 18836 [L-FMU/DM]Busy Device Changed. Type:imu0_local, <ID:17 idx:1-->ID:8 idx:0>, change tim
312.809 : 18836 [L-N_MIS]Exit mis 2. New mis 3
312.809 : 18836 [L-N_MIS]Switch new mis 3 req 2 from mis 2 req 1
312.809 : 18836 [L-FLYMODE]SWITCH2HOVER!
312.877 : 18839 [L-FDI][FDI] ns atti(0) tilt is outlier
312.877 : 18839 [L-FDI][FDI] ns atti(1) tilt is outlier
312.885 : 18840 [L-FDI]NS(0) FUSION(0): fault on , disagree
312.885 : 18840 [L-FDI]NS(0) FUSION(1): fault on , disagree
312.885 : 18840 [L-FDI]ns req:fdi,0to1,reason:disagree_tilt,result:fail for disagree_tilt
312.885 : 18840 [L-FDI]fatal error: no ns with level < 4 !!!
313.224 : 18857 [L-FMU/LED]action changed. imu error:ns_abnormal(3)
316.058 : 18999 [L-FDI][FDI] ns atti(0) heading is outlier
316.058 : 18999 [L-FDI][FDI] ns atti(1) heading is outlier
316.076 : 19000 [L-FDI]ns req:fdi,0to1,reason:disagree_yaw,result:fail for disagree_yaw
318.510 : 19122 [L-FDI]NS(0) FUSION(1): fault on , magn_heading_err_large
319.547 : 19174 [L-FDI]NS(0) FUSION(0): fault off, disagree
319.547 : 19174 [L-FDI]NS(0) FUSION(1): fault off, disagree
319.608 : 19177 [L-FMU/LED]action changed. Normal Flash(0)
319.608 : 19177 [L-FMU/LED]type:0, normal flash action:
319.608 : 19177 [L-FMU/LED]c0:0,15;c1:0,3;c2:0,13;c3:2,3;c4:0,10;c5:0,3;c6:0,10;c7:0,3
320.904 : 19242 [L-FDI]NS(0) FUSION(1): fault off, disagree_with_mini_filter
320.924 : 19243 [L-FDI]NS(1),switch to normal filter
320.924 : 19243 [L-FDI]ns req:fdi,0to1,reason:normal,result:succeed
320.924 : 19243 [L-FMU/DM]Busy Device Changed. Type:imu1_ext_ns, <ID:8 idx:0-->ID:17 idx:1>, change ti
320.944 : 19244 [L-IMU]userId[3] idx[1] mini_filter_used state:0
322.081 : 19300 [L-BATTERY]get_cell_voltage_callback_ack failed!||
323.025 : 19348 [L-FDI][sensor_api_info] head(2,0,31,4).|
324.195 : 19407 [L-FDI]NS(0) FUSION(1): fault off, magn_heading_err_large
324.242 : 19409 [L-FDI][FDI] ns atti(0) tilt is outlier
324.242 : 19409 [L-FDI][FDI] ns atti(1) tilt is outlier
324.255 : 19410 [L-FDI]NS(0) FUSION(0): fault on , disagree
324.255 : 19410 [L-FDI]NS(0) FUSION(1): fault on , disagree
324.255 : 19410 [L-FDI]fatal error: no ns with level < 4 !!!
324.295 : 19412 [L-FDI]NS(0) FUSION(0): fault off, disagree
324.295 : 19412 [L-FDI]NS(0) FUSION(1): fault off, disagree
325.055 : 19450 [L-FDI][FDI] ns atti(0) tilt is outlier
325.055 : 19450 [L-FDI][FDI] ns atti(1) tilt is outlier
325.073 : 19451 [L-FDI]NS(0) FUSION(0): fault on , disagree
325.073 : 19451 [L-FDI]NS(0) FUSION(1): fault on , disagree
325.073 : 19451 [L-FDI]fatal error: no ns with level < 4 !!!
325.434 : 19469 [L-FDI][FDI] ns atti(0) heading is outlier
325.434 : 19469 [L-FDI][FDI] ns atti(1) heading is outlier
325.893 : 19492 [L-FDI][FDI] ns atti(0) heading is outlier
325.893 : 19492 [L-FDI][FDI] ns atti(1) heading is outlier
326.789 : 19537 [L-FMU/LED]action changed. imu error:ns_abnormal(3)
327.524 : 19573 [L-FDI][FDI] ns atti(0) vgz is outlier
327.524 : 19573 [L-FDI][FDI] ns atti(1) vgz is outlier
328.122 : 19603 [L-FDI][FDI] ns atti(0) heading is outlier
328.122 : 19603 [L-FDI][FDI] ns atti(1) heading is outlier
328.963 : 19646 [L-FDI][CTRL]: fault on , height_ctrl_fail
328.983 : 19647 [L-RC]craft ctrl failed!!!
329.422 : 19669 [L-FDI]NS(0) FUSION(1): fault on , magn_heading_err_large
329.881 : 19692 [L-FDI][CTRL]: fault off, height_ctrl_fail
330.739 : 19735 [L-FDI][CTRL]: fault on , height_ctrl_fail
330.965 : 19746 [L-FDI][FDI] ns atti(0) vgz is outlier
330.965 : 19746 [L-FDI][FDI] ns atti(1) vgz is outlier
330.998 : 19748 [L-RC]craft ctrl failed!!!
332.685 : 19832 [L-FDI][FDI] ns atti(0) alti is outlier
332.685 : 19832 [L-FDI][FDI] ns atti(1) alti is outlier
332.810 : 19838 [L-FDI][FDI] ns atti(0) alti is outlier
332.810 : 19838 [L-FDI][FDI] ns atti(1) alti is outlier
332.865 : 19841 [L-FDI][FDI] ns atti(0) alti is outlier
332.865 : 19841 [L-FDI][FDI] ns atti(1) alti is outlier
