- Joined
- Feb 22, 2019
- Messages
- 20
- Reactions
- 6
Problem? Dropped signal and lost control 100' up 20' away from me and it drifted into a tree and came down hard
Was unit in a crash? Yes
What have you tried so far? Swearing, lots of cursing, called retailer they said call DJI, called local DJI branded store and they can repair
What device are you using ( iphone , ipad, Samsung , etc)? iPhone Xs
What firmware are you running ( aircraft, remote controller)? All current
What Go app version are you using? Current
Any modification? No
Did you change anything or install any apps? No
Do you have a video or pictures of the problem? I have a video of it tumbling down through the tree, not much to see except it hovering in and around the pine tree for about a minute until the rear props contact a branch and it goes tumbling down.
Hello everyone, sadly this is my first post here after my Mavic Air crashed. So today I took my Mavic Air with me to work, I work for the local electric utility in substations and was going to be at one today that has some neat lakes and houses around that I thought would be cool to fly over. I know the manual says substations are a no go area but I was technically outside in the driveway a good 20' away from anything energized and the 40kV stuff was even further away so I figured I was good. And I was, after acquiring a good GPS signal I went up to approx 100' moved over the substation mat for a little bit then began raising up and moving towards my intended target of a lake 1/2 mile away. Came back in sport mode to the general area and switched over to regular mode to bring it home. Started bringing it down doing some messing around thinking I'd be fine since heading out I had no issues, unfortunately once I got to 100' I lost all connections and control over the drone. It drifted towards a pine tree, hovered for about 1 min and then clipped a branch pinballing through the tree before finally taking a hard landing on a truck in the driveway. Truck was fine but the drone isn't, more on that at the end. Now, I assume it dropped signal because I was over a substation, but I don't understand why it wasn't an issue headed out but was coming back. One other time I dropped signal like this in my driveway doing a dronie it dropped signal and returned home and hovered just above my head, it did something similar this time but hit the tree. I think this time it tried to go home but had its home point off and went into the tree instead, with no controller connected it just sat there until it crashed.
But, can you guys tell from the flight log if something else happened or if something is wrong with the drone? This is the flight log I uploaded to phantom help, video from the drone memory card goes about 2 minutes longer.
DJI Flight Log Viewer - PhantomHelp.com
With all that being said, I assume since I was over a substation DJI will not warranty this for me? which is fine, the manual explicitly says not to fly near them I guess their definition of near is a lot different than mine, haha. The positive is after recalibrating the sensors and replacing the props it flys again, but the rear landing gear/bottom motor cover is broken as is the front. The front one acts as the pivot for the antenna, somehow the antenna didn't break off but the piece its mounted into is broken so it won't stay folder or unfolded. I know the rear will just pop out and in, the front looks like it screws and snaps in, but it looks like I have to buy an entire arm to repair it? is that so? and can I just replace the hinge part or am I looking at an entire arm replacement?
Thanks everyone, pretty bummed.
