Mavic Air vs Mini WiFi diffrenet trasmission system
vadda
Italy
Hi,
does anyone know the specifications of the transmission system used on the Air and Mini?
In FCC mode I can't have the same range in an urban environment and I noticed that
on AirData the signal logs are different.
On the Air a column with the signal errors is displayed and even if the quality is low
the transmission continues to work up to 2.6Km, with the Mini instead I cannot go
beyond 1.3Km even if the signal quality in general seems better .
I know they are different measurements, I was wondering if there was a way to compare them
The logs are for the same path, same CH and Freq .
deepdark
