Mavic Camera Specs for VFX
Cabraswel
I have found the information kind of spread out but wanted to know if this is correct.
For the focal length its 28mm but the camera back is 0.243 x 0.136 effectively creating a 35mm lens from cropping. Just wanting to make sure this is correct.
Did some investigating and discovered is somewhere between 3.7-4.7 depending on where you get the info and a sensor size of 4.7mm x 6.3mm give or take. Again nothing solid even from the tech support or my own math from using the sensor width and the supposed FOV on the webpage specks but all pointing to that range.
tagir
