I gotta say....mine did appear to fly slower after the update. You may be on to something...
I sent my Mavic back to the factory for repairs. They kept my old one and sent me a new one and now it only flies 4 to 6 mph. When I first got it it flew the normal 20 mph for about 5 minutes and then it would only go 4. I can't turn off the obstacle avoidance as there isn't a way to do it in the new firmware. Please don't mention wind as this is over several days of trying to cure the issue. None of the days had wind over 4 mph at any elevation. I can't use the drone at these speeds.I gotta say....mine did appear to fly slower after the update. You may be on to something...
Why can't you turn OA off? Surely they haven't removed the whole visual sensors menu tab?
If I knew why I couldn't turn it off this posting wouldn't be here. There is no place to turn it off. I can turn off the downward sensing but not the forward sensing. It isn't in the program anywhere.Why can't you turn OA off? Surely they haven't removed the whole visual sensors menu tab?
If only the downward sensors setting is visible then you are one menu too far in. You need to go back to the first page of the sensor settings menu.If I knew why I couldn't turn it off this posting wouldn't be here. There is no place to turn it off. I can turn off the downward sensing but not the forward sensing. It isn't in the program anywhere.
Yes! Thank you. With your help I found how to turn it off and it flies like it used to.If only the downward sensors setting is visible then you are one menu too far in. You need to go back to the first page of the sensor settings menu.
