Mavic mini battery charging
This is the original charger that came with the package fly more comboView attachment 96733
Here’s what I have found to give high power supply to battery charger, whether the fly-more battery unit or directly to the mavic mini.
Look on ebay for google pixel charger, 18 watt. It usually will come with a USB-C output socket and be priced somewhere around US $10. Most that I have purchased were good units. Then, from ebay or amazon, get a USB-C to USB-micro cable. these should be capable of 3Amps or more. Put the two together and you have an industrial-strength charging system.
Thank you for the info I just got a 18 watt and it works a lot faster. Thanks again
will charging on 10W adapter is good for my MM battery health? I mean charging slowly is good for battery on long run than fast charging with 18W adapter ?
jbk420
