Mavic mini owner
Welcome to the forum from Georgia. You will find plenty of helpful information and advice in the forums. Crashing is part of the learning curve. Wish you well in your flights.
Welcome to Mavic Pilots! :) Enjoy them forum!Thumbswayup
I'm new too, this is what I've learned:
1) It always replaces props in pairs, so you avoid vibrations.
2) Do not fly with more than 28km/h wind.
3) At higher altitudes you probably have much stronger winds.
4) In case of strong wind, always fly against it, this way when you are with low battery the drone will be able to return without surprises.
5) Always check to set the RTH and the altitude needed to come back without crashing into anything.
Reactions: LankALank
Good advise
Reactions: Guarf
Make it a habit not to fly with high wind gusts, stay below 15 mph winds and you will do great. Always keep good eye contact with your drone and be alert to any warnings your Mini gives you. The Mavic Mini is a capable little drone just know its limitations and you will do great.
Reactions: Guarf
CraigAE
