Mavic Mini repair advice
sumsunara
New York
Hi,
I need to open the case of the Mavic Mini, however, one of the screws is really locked pretty tight, and the screw is losing it's shape. Advice would be much appreciated.
Thank you,
Hi Easyjeans.
1. I used the screwdriver that came with the drone.
2. Your answer is not helpful.
Respectfully
Most of the screws are locked using loctite to keep them from walking out due to vibrations. Also the screw head isn't a normal phillps, you need a specific driver for that. It might have to be drilled out because of the damage.
had the same problem, used a Dremel mini drill with a diamond sharp cutter, and made a screw for a flat screwdriver, it works
it might be a Posi-Drive tip
It might be locktited
put the tip of a soldering iron on the head and give it a little heat to see if it will break loose
attifko22
