On the front of the Mini controller are two buttons. What does the one on the right actually do? Is it something in a menu that needs to be set up? At least the gimbal wheel, and take pictures button on the left I figured out.
Thanks
If you press the right button once, it puts you into single snap shot mode, a second press of the button will take a snap shoot. Same on the left button, first press of the button moves you into video mode and second press starts a video recording. When I first started flying, I would press the left button thinking I had started recording a video clip and then get disappointed after a flight when I discovered I failed to press the button a second time to actually start recording.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
