Mavic mini se advanced parameters
Kingsport, TN 37660, USA
Can anyone tell me which ground station apps or any apps you can use to change the parameters for dji mavic mini se, or does anyone know what all apps are compatible be it android or iOS also can I get some ideas for fun advanced parameters to change around
Thanks
Greetings from Birmingham Alabama USA, welcome to the forum!
Drop by the pilot’s
check-in to introduce yourself
As to your question, I have no idea if the Mini SE is compatible wth any Ground Station apps
If you want to modify the firmware parameters of the drone then drone-hacks software on a PC may be what you're after. If you want to explore further then in your mavicpilots profile enable access to the software mods section (normally its hidden and you have to specifically opt in ti get access) and search in there. That's the section of the forum where discussion on this kind of modding should be kept 👍
Ok awesome that’s exactly what I was looking for they don’t make it very easy to find on here again a million thanks
Reactions: dirkclod and scro
mahasingh
