Mavic Mini SE top shell screw totally stripped out
Status
Not open for further replies.
MiniMagic
United Kingdom,
It is completely stripped. I bought it with a cracked shell thinking I could easily replace it, the seller didn't mention that it was stripped though.
I can't complain as I repaired the crack with lock cylinder dust and cyanoacrylate glue, it has a scar but it's solid and has no issues flying.
I would though still like to replace the top shell as I bought a replacement (scar free!) the problem is that that damned screw will not budge.
see images from the repair of the crack, a healthy screw, and the damned stripped screw.
Is there a 1mm/1.5mm screw extractor bit that could do the trick (is that even possible considering the screw is in a recess?
I know that there are some creative minds here on the forums and hoping that someone can come up with a good workaround for me, failing that it looks as though I will be stuck with Scarface...
Thanks guys.
Hugh
Reactions: Cafguy
Use a torx driver it will grab and let you turn the screw.
CAREFULLY !!!!!! Epoxy a tiny bolt or other type screw to the bad one seek advice and do it carefully and you may just get the screw to budge.
Duplicate thread CLOSED!
See link below for the original thread:
Allen
Status
Phly858
