Mavic Not Descending
Gynan1
Hi all,
Hope someone can help. when I fly my Mavic pro and attempt to descend the controller tells me that the Mavic is in landing mode, when it is about 30m in the air. the Mavic will not descend and the only way I can get it down is to hit return to home. I tried cleaning sensors with no joy.
Any ideas on how to sort this issue? see attached flight file.
Here are the usual cases where the downward sensors incorrectly detect the ground is near:
  • Something is dangling beneath the Mavic (e.g. a GPS tracker antenna)
  • A 3rd party accessory is installed beneath the Mavic (e.g. extended landing gear)
  • The sensors needs to be calibrated like this
  • The sensors are dirty and need to be cleaned
  • The sensors are damaged and need to be replaced (not a common problem)
Reactions: Slat
Dispatcher
