Mavic Pro 2 crash, will not go forward or back.
fsu1991
Florida
Ok, drone hit a flag, dropped to the ground. One of the pins on a prop broke, i replace it but drone will not go forward or back. I calibrated both drone and contoller, no change. Help plz.
fibers or grass can wrap around the motor shaft under the propeller. Even a tiny amount of friction can prevent a motor from reaching the RPM necessary to "pitch" the drone forward.
With the drone off, spin each motor with your finger. Do they all feel equally smooth? If the motor that took the hit feels weird or stops sooner than the others, the shaft might be slightly bent.
Reactions: Cafguy
ScoobyPitt
