Good afternoon, first of all thank you all for your support yesterday. I have been flying today from the boat while underway and I was under the impression that having the drone near the boat "controller" it was all ok but the drone is set to go to it's max distance setting from take off point so I just went to home point settings to enable the drone to carry on following the boat by setting current aircraft position as a home point which is a pain, so I tried to set the other option that it must be the controller but apparently it is the screen in my case an iPhone 8 which gives an alarm "mobile device gps signal weak". I am now stuck trying to understand what should I do next or if I missing an accessory to enable the drone to follow me "controller" and enjoy sailing shots while underway. I am used to do a lot of cool stuff while at anchor but underway just starting ;-.) looking for any advise tanks in advance. attached two screen shots.![IMG_1774.PNG IMG_1774.PNG](https://mavicpilots.com/data/attachments/93/93615-5f0f9f5af6b62db9a053a874b6451765.jpg)
