Mavic pro black screen, please help
oh my, so the gimbal board is out of the question then. About the wifi board i think that it doesnt have anything to do with image transmission per se, as much as it has to do with the wifi connection when you are flying only by phone (switch the side selector to wi-fi). Dont know for sure though
I replace the ptz and gimbal ribbon cable even though the gimbal works flawlessly. whats weird is that recording and photo taking doesnt work, it seems to be glitching on mine. I have tried several sd's which i use in my mini2, mavic2pro and mavic2zoom but even after formatting them on a pc, or onboard the mavic it wont record anything, just creates broken video files!!! I hope to god its not the core board, such a waste :(
Yea mine does the same thing with the pictures and videos but I think it is the core board.
  • Sad
Reactions: gdanas87
yep i'm afraid the same is true for mine. Sending it in for repair to a local shop if the camera module doesnt work, will let you know how it goes... I hope its not our mainboard/core boards that are faulty, because these go steep for more than 150, at least! :( and i dont know if i am prepared to spend that much for my mavic pro, since its my "backup" tool in my arsenal. I primarily use the mavic zoom and mavic 2 pro
Hello guys I am back after a long time, finally sent it in for repair to a local Shop, he found out it was the ribbon cables connecting The gimbal board to the mainBoard/core board, and now its fixed :) thank God it wasn't the mainboard. How these ribbon cables became defunct is beyond me
Hello,
I have the same problem. Mine started after I crashed my drone and the ribbons cable was broken.and the gimbal fell out from the drone.
I replaced both cables and the plate that holds gimbal to drone.
Also had to replace one arm.
I finished my repair yesterday and the drone flies :) gimbal moves but there is black screen also when I try to change any photo and video settings it instantly set them back like it was before crash.
So I am wondering if camera is broken (not sure how to test it before I order new one)
Or I somehow put the video cable those thin wires opposite way. Or it could be something else.
So I had this problem awhile ago after a crash and I fixed it by downgrading the firmware on the drone. Through the dji assistant app on desktop. Try this and see what happens.
Riiich23
