Mavic pro controller issues
You say you use Go Fly app. That is not a DJI app. It is a third-party app you can get on Playstore.
You should download the Go4 app from the DJI website, it is not avalable on Google Play. Get it here:
DJI GO 4 - Download Center - DJI
It is listed as compatible with the Samsung S8 (I use it myself on an S7).
Thanks for the link I downloaded it and updated firmware it was suggesting and now have flight modes as you would expect. Only thing I've noticed is it's not as stable in the slight breeze as it was it was when I used third party app or since the firmware upgrade one or the other and I'm talking just take off hight it seems to drift now instead of holding it's position like it did and the breeze wasn't All that strong.. also which is not a big deal but with other app it had a land soft function I could hold joystick down and drone would come down fast but when it got to I think same height as take off height it would stop automatically while I'm still holding down stick then after a few seconds it would land soft.. I wasn't aware go4 didn't do the same and I smashed it into the ground pretty hard luckily no real damage just scratches
Reactions: LoudThunder
Thanks for posting as it will help others to be aware of third party apps.
The Go4 / Mavic Pro should have the same function.
Most DJI drones have bottom sensors to see the landing area before touching down for a safe landing.
If you're in "SPORT" mode during flight, it may have disabled the bottom sensors that resulted in a rough landing. 🤔
There may be settings in the Go4 app that applies to the Mavic Pro that need tweaking about the sensors.
Thanks for the reply I have to have a bit more of a look at the go4 app but basically once I downloaded it and paired it I updated the firmware it was saying then I used the take off button and basically only went about 3 mtrs off ground for a couple minutes and in hover it seemed to drift from it's spot by a few feet and not return to that original hover spot I had to manually move it back because it was getting close to bushes. With the 3rd party go fly app it seemed to sit still or at least return to it spot if it drifted a little
I appreciate your help fellow flyers
I have read your various entries and you seem to be a very basic beginner, even if you have flown drones in the past a little bit of Good Old Fashion Advice is always helpful…
Your brother paid a lot of money for that Drone, put a phone number on it. If the drone gets lost or stuck in a tree and it finally comes down when you are not around, give the finders an opportunity to contact you so it can be returned.
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
Fly On and Fly Safe…
Thanks for all the advice it will be a big help..cheers
Achernar
