I have a question for you guys, what device are you hooking up to your transmitter? Are you using an iOS device or an Android device?
The reason why I ask is because I've nagged about this issue for several weeks and I think I've found the link. I've had all of those problems I listed above, and at first I thought it was because of my microSD card because it only happened when I put a certain card in. Then it turned out not to be the card, so I returned that
P4 and got another
P4. Well, I changed a few things, and everything was OK at first with the new bird. But then the problem started again. This time I ran some tests with the microSD that came with the bird, and several other ones, and they were still giving me problems. So, I swapped that one out for a 3rd
P4. At this point, I was starting to hate the way the DJI Go app for Android and decided to buy an iPad
Mini 4 that I only use for my
Phantom 4. Well everything was great, no more problem. It was too good. So I figured I'll put my Galaxy Note 5 back in and see how it handles. Well, guess what, every previous problem I had came back. But, when i put the iPad back in the saddle, no problem.
I'm not sure what the problem is, but it definitely has something to do with my Samsung Galaxy Note 5 and/or the Android DJI Go app. If you are having problems, and you have another device available (borrow your family's phone or ipad or tablet), can you test out with the other device and see if you're still having the same problem? Please share what devices you are using.
ThanX!
