Mavic Pro Platinum NO circle in Quickshots
XTFalcon
Kilmore
As the title suggests there is no Circle mode in my quickshots just the other three dronie heilix and rocket.
Do I need to update firmware or something
thanks thomo
thanks thomo
Just use a POI?
[QUOTE = "RadioFlyerMan, post: 900130, membro: 78322"]
Basta usare un PDI?
[/CITAZIONE]
thanks thomo
Hi, there is no circle on the MP, there is the elix which is similar to the circle but with a height of variable height, the circle can be done with the Ackitiv track
Reactions: XTFalcon
If 'circle mode' means flying around a geographical point with the camera always pointed at that point - then you may get what you need from the 'Point of Interest' [PoI] mode. You can also get a 'roaming' effect on the PoI if you do an 'active track', but make the Mavic slowly circle the [moving] object it's tracking ...
Reactions: XTFalcon
geoff ellis
