Mavic Pro (series1) horizon
blitzrn69
I am just wondering if anyone of you guys had a perfect stable horizon. Comparing my mavic pro to my mavic air, the air has a really stable and level horizon.
Mine tilts whenever I yaw or roll. Then tilted on hover on some directions, wind around 3-7 mph
My mavic air was perfectly stable on strong winds.
My question; is it a defect? Or a normal thing with the mavic pro?
Thanks
"Gimbal Mode", is it set to "Follow"? or "FPV"? (found under "Gimbal settings" in the go app)
Actions suggests it is set to FPV when you want/expect Follow setting that your Air is using?
Gimbal mode is set to follow. My drone build date was recent 08/2018. It is a replacement drone from DJI. No crashes/hard landing. I did all calibrations both through app and dji assistant, cold imu. Same results.
Jason Wayne marjoribanks
