Mavic went insane
Not really - immersive mode is supposed to track only left and right head turns. Vr mode shouldn't move the drone, just rotate it and controle gimbal.
I don't know...I just installed Litchi and I already experienced a lot of problems with it.
Reactions: Mike357
Quick update (maybe someone would find it useful) - I contacted DJI support and after a long correspondace that really pissed me off, I managed to get this graph from them. It appears that dron received an UP command from SDK (Litchi) and I have no idea how can that happen in VR mode. No response from Litchi yet.View attachment 23141
Aside from confirming that it ignored the sticks, the correspondence between sdk_thr_z and relative_height looks a bit weak.
Al
I just had an accident using a Mavic in Litchi vr mode - my drone went completely unsane: it started spining uncontrolably and then started ascending really fast until it hit some tree branches. How can I found out who's fault is it...and does it evem matter?
Drone itself doesn't look damaged from thr outside, but gimbal mottor doesn't seem to work correctly and I get some errors. Any advice what to do? Thanks in advance
U had the drone set to immersive mode hence the signal came from SDK in Lichi. If u tilted your head up it would literally fly up at a rate of knots. If you til your head left it would move left and so on. It would be the only explanation. I've been flying Lichi since I've had my drone and never had any issues. Used the VR mode as well but turned immersive mode off as I didn't want to get into head tracking.... I prefer flying with the sticks
almost sounds like a motor or prop went wrong. And the spinning is part of how the mavic tried to stabilise and land. This is a function of many Dji drones. The logs will tell you more.
Yeah, this is a strange one. I was going to guess that the Mavic got caught in an updraft. The altitude gain occurred before the erratic flight. It was flying along very close to the ground and then started rising with no throttle at first. It then continued to rise with full negative throttle.
At time 291.624 the AC declared a ctrl failure, from the eventLog stream.
291.624 : 1996251525 : 21920 [L-RC]craft ctrl failed!!!
This was after it rolled left uncommanded
The only thing I can think of is that it was caught in an updraft that then got stronger on the right side.
Following this is when the motors started trying to compensate causing the erratic flight.
Maybe a bird grabbed it?
I have been encountering a similar issue when in a particular spot in my garden, the mavic goes loony and starts ascending for no particular reason. The only problem is that there are trees just a couple of meters above and the rc has a hard time responding to any input given. My guess is that there is some kind of electrical field or magnet interference but who am I to say, I'm no specialist ;) . I just avoid flying in my garen now and all is fine.
At first this was my guess also, but drone flying full speed into tree branches really seems like an overreaction to magnetic interference. I will definitely not fly in my garden again...at least not in VR mode.
hesitantextraneous
