- Joined
- Jun 24, 2019
- Messages
- 220
- Reactions
- 199
It was suggested to me that I post my experience in this forum since the cause of the crash was known:
I have just experienced a dive into water over the weekend. Luckily I was able to retrieve my drone the next day. It's now in a bag of rice to try to wick all the moisture from the drone. Also, lucky I have Care Refresh so once I get it dried out I will evaluate the need to use that service. If it works again, my loss so far is one battery (with less than 40 cycles and the props).
By the way, if anyone knows what can happen to a drone spending the night in a fresh water pond, please let me know. If there are any tests to perform to check the airworthiness of my drone, please chime in.
I have read quite a few reports of drones simply dropping out of the sky due to loss of power when batteries had enough charge to get them down safely.
This incident is also a good reminder not to fly over people or cars where a falling drone can cause injury or damage.
In my case, the reason the drone took a dive into water was clear. The battery separated from the drone while I was descending rapidly from 90 to 60 meters. The screen gave the red warning "disconnected" and as I looked up, the drone was falling with the battery about 10 feet above and beside the falling drone.
I discussed this failure with an industrial designer and pilot with 30 years of experience. His conclusion was that this is a design flaw, as a critical non-moving part such as the power source must have a fail-safe mechanism.
I had checked my battery for any sign of swelling or abnormality before every flight and I make sure to push it down firmly to hear the clicks by the locking mechanism so there was no error on my part.
The sudden and rapid descent caused the separation. Somehow the locking mechanism failed.
From now on, I will try the following fix:
Wrap a velcro strap around the body of the Mav Zoom and add a compressible material on the top to always maintain pressure, in case the locking mechanism fails again. Perhaps someone with talent can design this and add this fail-safe to existing models that use the same design as the Mavic Zoom.
Should I upload any other info? Flilght log, video, etc.? Not sure how to do this. Any suggestions?
