Mavic zoom crash
Teejag
Zimbabwe
Hi guys had an incident. Had no control over mavic zoom was barrel rolling and spinning down to the ground then recovered and did it again. Sadly hit the ground did some damage recovered and I flew it back.
just been looking at the flight logs and seen that it is showing red cell deviation at some point. Has anyone had this
Small cell deviations aren't a problem and are common.
Large cell deviations might cause the drone to fall from the sky in extreme cases but not barrel rolling in flight.
Post your flight data and some experienced eyes might be able to see what the data is saying.
Is the flight data the .txt file
The battery cell deviation and one cell go hollow just before it starts 2 tumble then recovers age happens again.
have posted it up ahead in the other link
That DAT log is the wrong one ... this flight is associated with the DAT that ends with .FLY000
But already a message readout from the TXT gives a hint about what failed ...
And here what's shown in the TXT from the time were the gyros probably failed ...
Alot of graph's but something starts to happen at 243sec ... the downward speed picks up without throttle inputs. Then at 248sec all goes haywire with rapid speed increases in all 3 axis (x,y & z) ... you don't have time there to send so many stick inputs but in relation you put in some short throttle, elevator & aileron inputs
See if you can find the right DAT & post it up.
Reactions: Thomas B and Teejag
here is the flight record. I can't open it up to see the motor speeds and stuff like that just not sure how to do that
The minor cell voltage differences had nothing to do with the incident.
You can see a summary of your flight data here:
You were hovering normally and gave the Mavic a touch of throttle to climb an extra two feet when 175 feet up, at 4:02.8 something happens.
The drone pitched 73° .
At the same time it rolled left 122°, started spinning anti-clockwise and losing altitude.
You left the joysticks centred and as the drone fell further, the falling, pitching, rolling and spinning all became less severe.
At 4:12.6 and 22 feet higher than the launch point, the drone started to gain height. The joysticks were still centred.
The drone reached 51 feet at 4:16.2 and appeared to have almost stabilised when it all started again.
The drone fell tumbling and climbed again, the climb being fairly stable.
The drone stabilised at 4:23.7 at a height of 21 feet.
You flew it until 7:41 when you landed safely.
This incident looks pretty strange.
It's odd that the drone recovered and climbed, particularly without any control inputs from you.
I've not seen anything like it and can't think of a likely cause.
The event as such with a massive flight instability may very well be explained by a failing IMU. When this fails the data needed for a stable flight no longer can be gathered.
But agreed, it's strange that it is recovering ... hopefully we can see the causes once the right DAT is provided.
With the data already provided though... I can't see any problem approaching DJI with this.
Below in short for those eager to learn:
"For a drone to fly perfectly, the IMU, gyro stabilization and flight controller technology is essential. Gyro stabilization technology is one of the most important components, allowing the drone to fly super smooth even in strong winds and gusts. The gyroscope needs to work almost instantly to the forces moving against the drone (gravity, wind etc) to keep it stabilized. In the vast majority of drones, the gyroscope is encompassed or integrated within the IMU.
An IMU unit works by detecting the current rate of acceleration using one or more accelerometers. The IMU detects changes in rotational attributes like pitch, roll and yaw using one or more gyroscopes. Some IMU on drones include a magnetometer, mostly to assist calibration against orientation drift.
On board processors then continually calculate the drones current position. First, it integrates the sensed acceleration, together with an estimate of gravity, to calculate the current velocity. Then it integrates the velocity to calculate the current position.
To fly in any direction, the flight controller gathers the IMU data on present positioning, then sends new data to the motor electronic speed controllers (ESC). These electronic speed controllers signal to the motors the level of thrust and speed required for the drone to fly or hover."
An intermittent electrical connection in the flight control logic could create this scenario. Generally these occur at the point where cables mate with connectors, or where the individual wires are crimped into the connector bodies. Unfortunately they can be anywhere, and as intermittents are very difficult to find.
Reactions: Gindra and Teejag
here hopefully this is the correct one thanks very much for all the information very interesting. was soo strange I just thought to try keep sticks centred wasn't sure what to do. the first one it recovered so the the next time it was just too low.
The two events each look much like a lost prop in terms of attitude and height excursions, but of course the stable flight in between and afterwards rules that out. In fact it's rear left motor failure:
The rapid pitch, roll and yaw excursions are typical of loss of propulsion at one motor.
The continuous CCW yaw tells you that it has lost propulsion on a CCW motor, i.e. front right or rear left.
The motor speed record shows that it is rear left.
And the motor demand PWM data show that the slow rear left motor was not commanded - the FC was requesting nearly full speed from that motor.
That's hardware failure.
@sar104
I can also clearly see that the left motor isn't performing ... but it looks to be more to it.
When the event starts & until the AC lands a lot of errors is indicated, both position, velocity & GPS consistency errors. The position error remains until flight ends.
Hardware failure yes definitely ... but is it the motor or something else that effected it?
Or do I misinterpret thing's ..?
@sar104
Those kinds of errors are commonly triggered by such an extreme loss of craft control, so unlikely to be causal or indicative of any other problem. And the fact that the motor slowed almost to a stop despite the PWM holding at nearly 100% clearly indicates mechanical or electrical failure of the ESC/motor. The recorded motor current stayed high too.
Reactions: NedKelly and slup
...Those kinds of errors are commonly triggered by such an extreme loss of craft control...
...The recorded motor current stayed high too...
OK..
Yeah ... that was seen in the magMod graph also.
Thank's sar104 Thumbswayup:)
Reactions: sar104
The only thing I found strange on the flight log I saw that the battery starts showing warnings just after the bird starts to spiral
That was most likely due to the current spikes as the FC attempted to spool up the faulty motor:
I had an esc failure the day before, after an update and it said restart the drone if the problem persists please contact DJI.
And I did that and the error extinguished. Wonder if that’s all something to do with it.
I think that it's pretty well established from the logs you provided that this wasn't the pilot to blame, a bird strike shouldn't have lasted over 40sec. The ESC error may very well have something to do with this ... but with that said, I think your next step should be to contact DJI for their point of view.
artyboy
