Memory card
onahi2002
Essex. UK
ill be needing to buy a memory card for my trips away. I know they have to be a certain spec for speed etc, But what is the favoured size. Im sure I read somewhere that only go up to 64GB ? Why not 128 ? Or even 256 ?
Whats the general view ?
Oh and how long video do you get with each size ?
Cheers
If you go over 32gb, you will Want to format to Fat32.
Above 32gb is exFAT format which will cause gimbal resets on MP/MPP.
M2 not so much, but still
The good news is you can format any card and any size to FaT32 :)
using this utility
Re time. 32gb is about 3 batteries/30 mins approx at 4K with Mavic 2,
But it's cutting it close. Better to go with a 64gb at least. Much Faster too.
Recommenced Samsung Evo +/Sandisk Extreme. Any size
MP/MPP a bit less.
using this utility
MP/MPP a bit less.
You can format the card in the drone using the app ?
You can format onboard but if it is above 32GB, it will be formatted ExFAT which as was pointed out, tends to cause gimbal resets.
Be sure the card you choose is U3 certified, especially if you record in 4K.
Yes.
I have never had a gimbal reset problem related to formatting 64-128GB SD cards in the drone.. with M2P
However you may want to try yours to see what happens before you travel to a shoot location.
My post was in response to MK!'s response which derailed me from the thread focus. The gimbal reset problem was with M1 series and recently discovered it correlated with formatting ExFAT. I don't think anyone has experienced gimbal reset issues with M2. I know I haven't and I use 64G cards.
If you have an M2, then no, you should not have a problem. Just be sure the card is U3 rated. 64GB seems to be a sweet spot for economical and practical reasons. Practical because it's a good idea to swap cards or copy data from them frequently so that if something happens that you lose the card, you don't lose recordings/pictures from too many past flights.
Reactions: Thomas B
0x6e08715
