Mini 2 big problem
Josipklemen
Đakovo, Croatia
Hello guys, I have a big problem with my Mini 2.
When I try to turn it on it blinks 8 times with the second light on the left, and then it keeps blinking 3 times every few seconds with the first light next to the power button.
Cant start it at all, and he light up even when the battery is not plugged in.
Does anyone know what should I do?
Have you read the error codes in the manual?
Here's a snip from the manual:
Possibly a short circuit? Check for damaged pins or debris in the battery connectors. Has the drone been damaged in any way?
You get lights blinking with no battery?! Presumably only for a short period just after you've taken the battery out though? There's no other power source in the drone so I can't see how the lights could light up, unless it's plugged in via USB?
Tried connecting it to a computer and used DJI Assistant to reflash firmware?
So basically:
- drone is blinking if battery is inserted and no USB connected
- drone is blinking the same if no battery, but USB is connected
Do you have an option to try with another battery? (I guess not, but this would be the simplest way :) )
Regards,
G
dronecc
