How is the case that comes with the mini 2 from DJI? My understand is that it's not hard, so if I put it in my backpack it can get squished and ruin the drone?
Is the flymore combo worth it? I like the extra 2 batteries and the charger (everything else in that combo is not that important), although I don't like that the charger is sequential, meaning it can take 5 hours to charge all 3 batteries, instead of 1.5 if it would charge simultaneously, and the fact that 4 batteries would give the best mobility and endurance, since 3 batteries can stay in the charger and the 4th in the drone. There's also not much point in taking out the battery from the drone if it's the last one, since you can charge it inside the drone and use the same battery for the next flight. So I think I'll end up using the charger (if I get the fly more combo) with only 2 batteries. Unless I get 1 extra battery, to have 4, which brings me to the next point...
Annoying that Mini 2 lipo battery is 55 US while Mini 1 li-ion is 40. I could buy the Mini 1 li-ion, but I believe I can't charge it with the Mini 2 charger correct (uses 8.8V)? So only option is to have it charged inside the drone only? Can the mini 2 drone regulate the voltage to allow for Mini 1 li-ion battery to be charged?
I know reports said Mini 1 li-ion battery can be used with Mini 2 drone, did it turned out it's fully compatible (it won't move around in the drone or damage the pins)? I know the mini 1 li-ion battery is slightly smaller.
