Hello fellow pilots. As usual, seeking help from a like minded group of enthusiasts. I picked up a mini2 with a broken camera cable. The surgery was successful, however the patient will not sit still. When it takes off , inside or out, it will not hold position and wanders. When I try to rotate it does not rotate around its center, but rotates in an orbit around center. Iv replaced props with OEM, centered gimbal and calibrated the controller. Calibrated imu multiple times and compass. Iv tested the 3 modes with the same result shown in the video. The only thing I noticed, that was obvious, was there is a consistent head nod while trying to rotate around its virtical axis. Any ideas ? Thanks all!
