Mini 2 "RC signal interference" with 24 sats and less than 75 meters from homepoint at 60 meters distance (no obstructions)
I checked the Support page for the Mini 2 where there is a topic:
How can I improve signal reception?
The smartphone clamp of the remote controller houses the antennas. Make sure that the antennas are pointed toward the aircraft. Check the user manual for more information about setting the antenna direction. Additionally, 2.4/5.8 GHz wireless devices can cause interference to the signal. Please avoid high-density Wi-Fi signal sources, and consider turning off the Bluetooth on your mobile devices, as well as idle Bluetooth devices.
So I highlighted the part regarding signal interference and will try turning off Bluetooth to see if it makes a difference.
Anyone else on this forum should try the same and report progress.
just finished a 2nd flight in a different location. no issues. maybe it is a problem with the location.
Only time I had the interference was when I flew past a cellphone antena tower.
AKARekz
