MINI 2 Yaw and Pitch Speed adjustments not making any difference
littlelegs
Newcastle, England
I have tried changing the yaw and pitch speed, in advanced gimbal settings in real time while hovering but it doesnt seem to make a difference. I have only tried for cine mode. can anyone help
Probably need to be in p-mode (position mode) for manual yaw settings
Cinesmooth probably has presets for yaw and pitch
I just did this myself,works perfect.Once you make the changes,take off in normal mode then switch over to Cine once your up in the air..See if that works..
Thanks, I tried it taking off on cine mode and doing the changes and then leaving the menu to move the stick and wheel, I will try it tomorrow, cheers
Hi, you have options to make changes in cine,normal and sport modes cheers
Yes i realize that..I only made changes to cine mode as that is the only mode that i record in..What i was trying to say is you need to start your flight in normal mode then switch into cine mode for the settings to take effect..At least that is how it works for me..
Ok sorry I understand now thanks
HTTR
