Plenty of speculation but who knows. I'd upgrade and enjoy the mini 2 personally. Actually that's what I did just before the Air 2s came out. There's always something newer and shinier on the horizon !!!!!How likely is it that the mini 3 will be announced in April? I’m thinking whether to hold off upgrading my mavic mini to a 2 if everyone thinks the 3 is soon.
did Mavic Pro 2 cost more than magic pro platinum?
Dunno about that.
You spelled WAY better transmission and WAY WAY WAY better wind resistance wrong.Personally I would not buy a 2 because it is exactly the same device as the 1, with only very minor improvements. Same low light capabilities, same sensor, same lens, basically same resolution.
Better transmission and also slight improvement to the wind resistance.
Whereas the mini 3 will not only make the 2 obsolete, but pretty much all current DJIs;
The mini 3 looks to be a major departure in the design, with props never getting into the shot ever again, combined with no more horizon down tilt when flying upwind either. Obstacle avoidance is also a big feature for the sub250gram class.
This design will be used for future Mavic products like Mavic 4, Air 3, and so on.
So use your mini 1 and either buy the 3 in a few weeks, or buy heavily discounted 2s in a few weeks
If it is this good then i will buy it. That is after about a month in case of any issues like the mavic 3. Thanks for your detailed reply and imputPersonally I would not buy a 2 because it is exactly the same device as the 1, with only very minor improvements. Same low light capabilities, same sensor, same lens, basically same resolution.
How wrong you are. I had the MIni 1 then upgraded to the Mini 2 which is a world of difference. I posted this last year after owning and flying the MIni 2:Personally I would not buy a 2 because it is exactly the same device as the 1, with only very minor improvements. Same low light capabilities, same sensor, same lens, basically same resolution.
Here’s a list of the improvements that I have seen on YouTube videos comparing the Mini 1 to the new Mini 2:
1. OcuSync 2.0 instead of enhanced wi-fi.
2. Better wind resistance scale level 5. 18 – 23 mph ( 29-37 Km/hr) due to new motors.
3. Digital zoom feature. Up to 4 times.
4. 31 minute battery life.
5. Front arms don’t twist/flex as much as on the MM. Plastic covers instead of foam as on Mini 1.
6. 4K video 30 fps.
7. Better props (not so flexible).
8. Top speed up from 29 mph to 36 mph (46- 58 Km/hr).
9. High video bit rate increased from 40 mbps to 100 mbps which gives a better image on your phone/tablet.
10. USB C ports.
11. Quieter than MM.
12. Bigger remote battery 5200 mAh. Twice the size of MM remote giving 6 hrs of flight time.
13. The Smart Controller can be used with it.
14. Shoots photos in RAW now.
15. Still under 249 grams
16. 4K Hyperlapse
17. Battery smart discharge feature.
18. Customisable button.
19. Lipo battery not Lion like Mini 1
20. Better angle for flying into wind
21. Lighter than Mini 1 at reported 242 grams.
22. Improved Quickshots. Dronie goes back further etc
23. Pano added
24. Front light (different colours available).
25. The remote works with the Mavic Air 2 as well.
26. Uses 3 satellite systems. The European Galileo is now available should give better GPS lock.
27. The yaw sensitivity can be adjusted in all 3 flight modes.
Thanks for the detailed reply sir!How wrong you are. I had the MIni 1 then upgraded to the Mini 2 which is a world of difference. I posted this last year after owning and flying the MIni 2:
6. 4K video 30 fps.
10. USB C ports.
16. 4K Hyperlapse
23. Pano added
Unless you have actually flown both the Mini 1 and the Mini 2 you probably wouldn’t appreciate the difference. The Mini 1 was hopeless in the wind. My Min1 lost contact many times within 150 meters (no OcuSync) and initiated RTH. Several times it almost dropped out of the sky (bending props issue) etc etc. While the list is extensive there are many valid points in it.
The increased bitrate is only for 4K, which the lens and optics do not even process fully as there is no difference visually with the video on the mini 1 compared to 2.
Only buy mini 2 is you need 2 minutes extra flight time, and need to fly BVLOS as the controller comes in handy then.
If you need a drone with better image quality, wait for mini 3
This changes nothing about what I said. Btw i currently own both mini 2 and air 2sUnless you have actually flown both the Mini 1 and the Mini 2 you probably wouldn’t appreciate the difference. The Mini 1 was hopeless in the wind. My Min1 lost contact many times within 150 meters (no OcuSync) and initiated RTH. Several times it almost dropped out of the sky (bending props issue) etc etc. While the list is extensive there are many valid points in it.
If I remember well you said both are still in their boxes, so you never flew them.
