Mini 3 pro gimbal error after dji repair
szymank34
USA
I recently sent my mini 3 pro back to dji for repair after a small crash. The gimbal was repaired and now I still have a gimbal calibration error 1D020001, the gimbal appears to function correctly and when I do an automatic calibration on my control it says it's successful but the error still persists. Is there any way to clear the error?
Reactions: RodPad
Are you saying you sent in your drone to resolve this issue? If so, it sounds like you may need to send it back.
I agree with @msinger that there is still a problem.
Did you send it to DJI for repair?
I originally sent the drone back to dji for a completely stuck non functional gimbal with error code 1d010002, they completed a repair and returned it and the gimbal is now functional but showing a calibration error.
Reactions: RodPad
I would notify DJI of the issue and they most likely will have you send it back. I wouldn't put it off either.
Reactions: RodPad
Follow up with DJI. Perhaps they'll be able to walk you through some troubleshooting steps to resolve it.
Reactions: RodPad
DJI did not repair your Drone, They sent you a refurbished Drone BUT it has a problem. I would Talk to DJI ASAP. DJI is actually pretty good at stuff like this. They will send you another. I am sure its happened before but its probably very rare.
Contacted dji and was told I would need to return the drone again, customer service was great to chat with. Just bummed I will be without a drone for a while longer, crossing my fingers the next one comes back in perfect working order. Thanks for the help everyone!
It's disappointing, but good to hear DJI is going to take care of you!
Reactions: Cafguy and RodPad
Hey Guys,
When sending drones back to DJI, what is the actual destination ?
It depends on where you live and the destination of the repair center.
For those that reside in the USA, ( sorry, should have been more specific )
Reactions: RodPad
Reactions: RodPad
Reactions: RodPad
Yes, location?
I had P2V+, 2015, it just came out.
Problem with live video, I gave up it went to California.
Same year I bought a P3S.
Anyways, that unit went to California three times.
I took pictures etc, every number that was on it.
Three times yes, every time something was different.
Anyways, I get in too many details.
I'm not the thread starter.
I won't reply to this message,unless it is the op
Rod ...
Di recente ho rispedito il mio mini 3 pro alla dji per farlo riparare dopo un piccolo incidente. Il gimbal è stato riparato e ora ho ancora un errore di calibrazione del gimbal 1D020001, il gimbal sembra funzionare correttamente e quando eseguo una calibrazione automatica sul mio controllo dice che è riuscita ma l'errore persiste. C'è un modo per cancellare l'errore?
Ciao l'errore che visualizzi è relativo alla calibrazione del gimbal dopo la sostituzione di parti hardware, senza che abbia fatto una ricalibrazione montando sul drone un firmware di servizio. Quindi nel tuo caso l'assistenza o colui che ha riparato il gimbal del drone si è "dimenticato" di effettuare questa operazione. Ho una domanda per te: hai inviato il drone in riparazione all'assistenza ufficiale DJI oppure un'altro professionista tecnico non ufficiale?
I sent a defective RC-N1 in for repair in China, and they didn't fix it right, so I had to send it back at my shipping expense.
Sei sicuro di aver mandato il drone all'assistenza ufficiale? Quell'errore è dovuto al fatto che è stata cambiata una parte hardware del gimbal ma non è stata fatta una calibrazione con il firmware di servizio. Mi sembra alquanto strano che l'assistenza ufficiale DJI si sia dimenticata, visto che è una routine.
attifko22
