Mini 3 & RC-N1 - FCC modification
denes21
Manchester
Hi all. I have experienced some signal issues with my mini 3, its range is significantly smaller than the 10km stated. At 120m I could get 1km at most, and the most I got was 1.5km at [REDACTED] m of altitude which is still nowhere close. So, I became interested in an FCC mod for extended range, especially in areas with lots of interference. Unfortunately drone-hacks don't support the mini 3 non pro even though I would prefer them as it is forever and additional functions are present. Drone-tweaks offer a solution, but only for 12 months so I will have to rebuy it, so it is a bit too expensive considering this fact. I have also found 2 android apps, one on GitHub called DJI FCC and another one from youtube called mavic air 2 FCC , both are connected similarly where you have to plug the phone into the bottom usb c on the rc and press the button in the app, but none worked for my mini 3. So is there any real alternative to drone tweaks?
Bourguignon
