mini2 se Newby in Daytona Beach, Florida
Have a Hubsan x4 Pro that I fly occasionally. It's a nice, although large and ancient compared to this technology. Totally stoked with the mini 2 se
https://mavicpilots.com/dbtech-membermap/
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Hubsan Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone. But your Mini 2 SE does not need to be registered…
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 2 SE, including the User Manual.
Fly On and Fly Safe…
Nice job Loud Thunder, thank you, you covered most everything. I would also include advising to watch several youtube videos that actually show you all these things and quite a few more. And then watch them again. I have a friend who is a pilot that owns the mini 2 se and then it's $1000 brother, so I'm lucky to have someone who's proficient and treats it like a space craft.
Welcome to the forum! :)
Reactions: Sailorevad
Actually I thougth I did in the third from last paragraph...
"I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Drone. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby." "
But being remeinded again is not a bad thing...
LT Signing off..
LT Signing off..
It is not at all a bad thing to be reminded LT, and yes you did mention youtube didn't you. Thanks
  • Haha
Reactions: LoudThunder
Actually, it's not your fault that you missed that, i have been told that I write too much and that some folks fall asleep reading my "advice..." L 😁 L . . .
keem21
