- Joined
- Aug 21, 2017
- Messages
- 4
- Reactions
- 6
- Age
- 38
Why not do a search instead of starting a new thread on this? This site is loaded with content on the topic:
Search Results for Query: battery warmers | DJI Mavic Drone Forum
Someone posted a flight in -40°C last winter.
The problem is not the Mavic itself, it's the batteries. At lower temps they will only provide limited thrust. At lower temps the drone won't fly. From what I remember, this is around 35F but I'm not 100% sure.
I went skiing in January 2017 and flew my Mavic at an elevation of around 9,000 feet. Temp was probably 0C/32F. I did not notice any issues with flying at that temp....everything performed normally, and my flight times did not seem much shorter.
However, I live in Phoenix, Arizona and the summer temps are a different story. It's usually above 110F here all summer, and while I still fly sometimes at that temp, I feel like it's way too hot for my Mavic. When the drone comes back after a run, it's almost too hot to touch....so I am really looking forward to some cooler temps coming soon.
Bottom line -- if you are concerned about low temps, then just go slow, proceed carefully, and do some test flights without going too high or too far away. The best guidance you will get is from personal experience.
Will be fine at MUCH colder temperatures than that. I have flown for 15 minutes at -20C (-4F) without any problem.
Then the batteries were warmer.
Of course! How hard is it to keep that batteries warm before you fly?
Well, I'm 90-miles north of the arctic circle and I'm often out all day at -20C or colder. As a previous poster suggested, just keep a battery or two inside your jacket. Problem solved.
I thought there were issues with GPS and GLONASS in that area.
