Minor crash DJI MAVIC
junkaii
Hi all i recently knocked mr DJI mavic into a wall, didnt fall all the way back, it still managed to stabilize itself. At first the gimbal was not working but after restarting the drone it worked fine. Is there a need for me to worry about the drone motors or should it fly as normal?
You shouldn't have to worry if it starts up without any issues. However, inspect the broken props and make sure the 3 tabs that make the connection are intact. They can break off and still be In the motor. With the Mavic off, give the motors a spin and be sure the motors aren't catching or making any unusual noises. You'll get a warning if something is wrong during start-up.
Edited slightly because I felt my original answer was a little too nonchalant
Seems like no worry - you could invoke a gimbal calibration on the ground before your next take off.
Can you explain how to make the connection intact? (the part where you mentioned to check the 3 tabs)
the gimbal looks a little out of position to me.. however i am not sure. is the ribbons on top of the camera supposed to be seen?
Can you take a photo and post it?
are the ribbons out of position?
I hope someone replies. My MP is at DJI presently so I don't want to weigh in w/o a bird to look at and compare.
It is normal that these ribbon cables are visible, but it's important that they're correctly seated as well.
thread is relatively old.. do you mind if you tell me when your drone is back?
its fine, the timing doesnt matter. if you can update me, would be good. thanks !
SerenaKuvalis
