Missing flight logs in Android 4.0.1
PropPilot
Ontario, Canada
I wanted to start a new thread as I am seeing this mentioned here and there under other topics.
Title should be missing flight RECORDS
It appears that flight records disappeared in Android 4.0.1 but exists in 4.0.0
Can you please check if you are running the latest DJI Go 4 version 4.0.1 and can access your flight records ?
My 4.0.1 has three horizontal dots at the top right that when pressed, open up the configuration menus for the drone. I can see the flight logs and entries there that show various mode changes during flight etc. I am looking for the flight records that I have seen screen shots of that seem to capture flight time, distance, altitude etc.
Any thoughts ?
They are under the icon at the bottom left.
Yay !!!! Probably the only thing I did NOT press while trying everything.
In the first screen it is under the icon that looks like a paper airplane at the bottom left just above the DISCONNECTED sign
Thanks !
Yeah it moved in the 4.0.1 patch for some reason ....
Humbug4
