MM pseudo active track
scro
UK
Quite a few people have observed that the MM does a "pseudo active-track" when using the quickshot functions. Having played around a little bit with this it appears not to alter the trajectory of the drone, but rather just use gimbal movement to keep the target in frame. When doing a circle quickshot the flight path remains as a circle even if the “target” moves in a straight line. Anyone else made similar observations?
The only quick shot I have found that the drone will actually follow movement and change its course, is circle mode. In the others, subject movement simply moves the gimbal, as you said. Pretty cool follow me video from multi angles in circle.
Be sure to give yourself plenty of room! LOL
Yes, circle can do the trick if movment and speed are adapted! Check 51drones video at 04:10
Reactions: Capt KO
the_apple_cart
